xpensive wrote:For kilcoo:
What you have calculated is little more than the theoretical volumetric flow of intake-air at a 100% filling-ratio.
Thats all I've supplied numbers for.
The formulae are there for the rest as soon as an exit static temperature and exit area are known.
I don't know the exit area or temperature - if anyone does....
Oh, and the teams spend the extortionate amount of money to ensure they get damn near 100% fill (if not a touch over with smart design).
xpensive wrote:
What is interesting here is how big will the volumetric flow of 1000+ C exhaust-gas be after burning fuel and the air's oxygene to carbondioxide and whatever, when mass-flow of fuel is 50g per second?
The fuel is irrelevant - the density of air at 288 degK is 1.225 kg/m^3, as temperature increases, this will tend to reduce further. Meanwhile the density of fuel is 800 kg/m^3 (or thereabouts).
When we do calculations on aircraft engines, you may include the fuel mass (as its mass, not volume your measuring) - but even then its only a >1% difference or so.
