Is there a simple equation or rule for how weight affects the cornering and braking ability (i.e grip) of a car.
For example if you have a car that weighs 1000kg then add 500kg to that exact car is the ability to grip (create G) 50% less???
Yep, that's exactly what I was getting at when I wrote this:Jersey Tom wrote:Look up tire load sensitivity...
Jersey Tom and I are completely agreed, but I do think my answer was perhaps a tad more informative.Roland Ehnström wrote:when you double the mass you will also gain a lot of grip from the tires simply because they are pressed harder to the ground.
Why the sarcasm? Dont you know how the physics of a racing simulation PC game are made? Those are oversimplified versions of this.xpensive wrote:You are way too modest, Gaucho.
