brings up a "solution controls" box does anyone know what the "pressure-velocity coupling" i should use to solve for the Formula 1 car front wing??
(the selection include SIMPLE AND PISO)
No unfortunately not my own experimental data.....got the data from either of the papers listed below. I think the geometry is the same in both. I will add i just did a 2D simulation.
1.Zhang, X., and Zerihan, J., 2003, “Aerodynamics of a Double-Element Wing in Ground Effect,” AIAA J., 41, pp. 1007-1016.
2.Mahon, S., and Zhang, X., 2006, “Computational Analysis of a Inverted Double-Element Airfoil in Ground Effect.
