kilcoo316 wrote:The air temperature might be as high as 40 degC... but the disc temperature may climb to over 1000 degC...
So the delta is say, 950 degrees for a hot climate like Bahrain, and just 920 degrees for a cooler climate like England... that is a relative difference of 3%...
With regard to deltas, let's bear in mind what generates that change in temperature.
Slowing a car from 300kph to 150kph releases a specific amount of energy. Doesn't matter how hot it is out. Inevitably the majority of that energy goes into the brakes (there's drag and engine braking as well obviously). The specific heat capacity of the brake material will define what that deltaT is. Let's say its 1000C. Assuming the heat capacity on average doesn't change appreciably from 25C to 40C, or 1025 to 1040C, then the jump in temperature should be pretty close in either case.
Additionally, cooling rate is in a large part defined by that difference in temperature from object to free-stream, which shouldn't change much.
Air density is going to be
slightly less which will drop cooling rate, absolute temperature will be
slightly higher which, as kNt states, will change black body radiation.
Basically in one case you start at 25C and jump to 1025, the other you start at 40C and jump to 1040 (plus or minus, maybe 1037 or 1042.. but likely within the level of variation from braking zone to braking or lap to lap).
Difference should be pretty negligible in the grand scheme of things.
Commentators don't always get it right. There have been a couple items I've disagreed with S. Matchett about recently...
Also, for what it's worth Birel, at 500C avg temperature a 20F (~11C) jump is not 2.2% Gotta use absolute scale (K).
