question of solidworks CFD
Scania
Scania
I'm using solidworks 2008 & it have a add-ins call "COSMOSFloWorks 2008". but it always said "face<X> is not laying on the boundary between solid & fulidregion". what is the meaning of boundary between solid & fulidregion? what should I do to finish a CFD test on it?
Lightning McQueen
Lightning McQueen
Re: question of solidworks CFD
Hi Scania,
try to run the FLOWORKS>TOOLS>CHECK GEOMETRY before start to Solve the Analisys.
LMcQ
Scania
Scania
could you step by step to explaine how to use it?
Scania
Scania
I saw this problem today.....
kilcoo316
kilcoo316
21
Err... if thats your domain it is far too small.
Typical wind tunnel blockage ratios are 7% or below, but CFD would be lower again... order of 1%.
(Blockage ratio is the front cross sectional area of the test piece:windtunnel cross sectional area)
Scania
Scania
how the fluid face should be?
