Jersey Tom wrote:Don't think he's quite got it right.
But in any event. Has problem on corner exit... with what?
I'm sure he knows weight transfer thing is incorrect... but he says the rear end is lifting when he gets on the gas out of a corner. This isn't possible so I am trying to get more info from him.
PS:
"Ok without over complicating the problem, here is the main issue that I’m facing.
Exiting a hair pin corner, or any corner that requires heavy braking beforehand. As I reach the apex, apply throttle and unwind the steering wheel. Both rear tire will lift up, the kart essentially will be driving on 2 front wheels for a second or two, I can hear the engine spinning up rapidly because of this. The track is quite flat with no bumps.
Track is flat asphalt. Yes I’m sure it is flat as I’ve walked the track many time before morning sessions. This has never happened before with my other karts, something about this chassis with 48mm rear axle, and 5 rear bearing supports
I can physically feel the rear end of the kart getting higher, than dropping down. It’s as if I hit a bump, but there’s no bump to hit, and also the sensation is very smooth lift up, not an abrupt one when u hit a bump."
