Geezers,
Me and my mucker were wondering what the approx cost of a 2009 F1 nose cone is??
Any advice much appreciated.
Big JS
Agreed, sounds high. Tools are expensive, carbon fibre etc. is relatively cheap. But on the other hand, how many wings is made from each mould? With fast development each design gets obsolete in no time.flynfrog wrote: $55k sounds way to much they are made of carbon not dollar bills.
are you taking into account cost of designing the parts ? I bet even some relatively simple parts (like i.e. suspension arms) may translate into few hundreds engineering hours, which are quite expensive. first layout, CFD evaluation, tests in tunnel, stress and modal analysis, lay-up design (all of them more than once as designing is an iterative process), manufacturing process design, tooling, testing on the test bench, testing on the track, quality checks, etc., etc.flynfrog wrote:where are you pulling these numbers from? $55k sounds way to much they are made of carbon not dollar bills.
The tooling to make them would be the expensive part that and the hand labor to layup. The actual part is rather cheap to produce. Im not going to take a stab in the dark because I honestly dont know. But you could build a rather sizable chunk of a carbon airplane for 55K
in such case you are probably right.n smikle wrote:You are talking about the R&D costs.. But if you already did the R&D.. when a driver breaks a nose cone.. I don't think it would be that expensive to make a new one. (...)
I was assuming that would be the R&D budgetnoname wrote:are you taking into account cost of designing the parts ? I bet even some relatively simple parts (like i.e. suspension arms) may translate into few hundreds engineering hours, which are quite expensive. first layout, CFD evaluation, tests in tunnel, stress and modal analysis, lay-up design (all of them more than once as designing is an iterative process), manufacturing process design, tooling, testing on the test bench, testing on the track, quality checks, etc., etc.flynfrog wrote:where are you pulling these numbers from? $55k sounds way to much they are made of carbon not dollar bills.
assuming you are updating the car more than once throughout the season it means you have to go trough all this activities just to make few, maybe 10-15 parts. having that in mind I think prices mentioned here could be called a bargain.
