I was always under the impression to get more heat into the tyre you would lower the pressures a bit to create a bit more movement in the walls (causing friction etc).
I've just read a small article that says to get more temperature into the tyre surface you increase the pressure. This apparently puts the stress onto the tread (causing heat) rather than the side walls.
Thoughts on this theory?
