I have been thinking about how we can get cars closer to more and more overtaking every race. I have a few opinions and Im sure there is a good few other people here with opinions on how we can get the cars closer. The 2009 regs helped allot, probably brought the amount of turbulent air down from -2.0 to -2.5 to the car in front to around the -.5 to -1.2 marker, but Im sure we can get allot closer than that.
What would you alter on the cars to get them to be able to follow the car in front closer and create overtaking????
My opinions:
1) Front Wing: I much preferred the 2008 spec front wing, so id like to see them brought back, but closer to the ground, almost 2009 low, but not as low as that.
Moveable aero allowed as many times a lap as a driver likes on the wing wheel on the steering wheel, but can be linked to a multi map setting on the steering wheel as well, but only for a maximum 90 seconds every 3 laps. Moveable aero would be up to +/- 10 degrees.
2) Rear wing: Id probably get the 2009 spec wing, but 200mm, standard wing setting for all is 30 degrees, although id allow the movable aero elements to be +/- 5 degrees. Same as the front wing, unlimited adjustments via the wing wheel, but adjustable via the Multi Map wheel.
3) Diffuser: Allow DDD, but these should be less steep than a conventional Single Diffuser creating less downforce. Which would be allow SDD cars to have a steeper angle to try and get teams to use them.
4) KERS: Banned.
5) Engine Overdrive: Allow the cars to run at 19,000RPM or "Unlimited" for 10 seconds each lap, this would replace KERS and Im sure that the teams would be much more responsive to this could get more high speed overtaking.
6) Appendages: All turning vanes on the sidepods are banned, same goes for wheel dustbin covers. All under nose and flow directors to be banned under where the drivers legs are. However, engine cover details to be allowed, thus giving the centre line a increase of 250mm in this area, but only one flow director is allowed here.
7) Tyres: Rear tyres to be increased in size by 50mm, front tyres to be decreased in width by 50mm, think 80s rears with early 90s fronts.
What would be your proposals???
