inspectah wrote:
I would like to know why nobody has even tried to do anything about the aerodynamics of the helmets?
Actually helmets makers do spend a lot of time in designing the helmet from an aerodynamic point of view, mainly the aim is to reduce the stress on the drivers neck (then improve efficiency of internal ventilation etc) but most also work in cooperation with teams to optimise the airflow in the area around it and to the air intake (I remember I read a paper about that I'll try to find it again). Not necessarily the aerodynamic study leads to something radically different, on the contrary, often the aim is to achieve the best possible result with the smallest modifications to the shape and that’s surely the case for an helmet since the imperative is safety. Just because the helmet doesn’t look extreme like the one used by the skiers in the 1 km downhill it doesn’t mean that its aerodynamics isn’t carefully evaluated. The current shape is probably the best compromise considering all the design requirements, the continuous movement of the head, and the current knowledge.
Obviously if in the next future a driver will use an helmet with a revolutionary shape I reserve the right to post here an enthusiastic message praising the brilliant design
