I had read somewhere, a while back, about the benefits of D shaped tubing/channel on flow rates for a fluid as it travels through a bend. I can't recall how great the benefit was for a D shaped channelling. But from what I recall, it was more efficient for the fluid (or gas?) to be pumped through a D shaped tube when making a bend, where the flat portion of the D shaped tube formed the inside of the bend.
The reason I'm asking is mainly out of curiousity, and part interested if there is any benefit to pumping lower velocity water systems. I'm thinking of agricultural spayer systems, by the way. Or even lower velocity fluid systems too.
