I'm having a strange problem with brakes on my car (Honda Integra Type-r) and are hoping somebody may be able to help....
I changed the disks and pads for standard items due to brake judder. After about 2000 miles they started to judder again but only when very hot.
I then changed them for Brembo drilled disks and uprated DS2500 brake pads.
Again about 2000 miles later they judder but only when they are very hot.
The car is driven VERY hard to be fair but I don't understand whats happening to make them judder only when hot.
We once measured the brake temps and after braking, pulling over and getting the gauge on the disks were circa 420deg C. I;m not sure if that's classed as hot for a road car but its a bit more info for you.
Any idea what could be causing this strange only when hot and after multiple heat cycles issue?
Many thanks.
