Hi there
I have a question about F1 engine RPM.
I know that these engines are capable of doing over 20000 RPM,but what's the highest possible RPM an F1 engine could reach before braking down?
Thanks
by
From what I understand mean piston speed is the general rule.xpensive wrote:That would be for certains parts Terry, such as con-rods, but for other parts I think speed might be the limit.
Scotracer wrote:Mean piston speeds are usually pretty constant over IC engines...
Well yes, but an engine of similar tune will have a similar MPS limit of another. Of course some agricultural engine wont match, for example, the Honda B18C engines.Krispy wrote:Scotracer wrote:Mean piston speeds are usually pretty constant over IC engines...
Mean piston speed limits are usually constant....the piston speeds vary alot depending on how "high strung" the particular engine is. Do you agree?
35-39mm IIRC...xpensive wrote:I don't know the stroke of an F1 engine of today, but 45 mm shouldn't be that far away, which means 30 m/s a 20kRpm?
