Formula 3 regulations
kreuzberg
kreuzberg
Hi guys
Im wondering if anyone here knows onything about Formula 3 regulations, specifically regarding the suspension systems and what the teams can change regards this.
From my understanding of the regulations, teams are free to design their own suspension systems as long as they conform to a few general regulations (max track, cross sectional area ratio and symmetricy constraints, angle of attack, have to some sort of suspension to provide movement in the wheel other than from the fixings etc)
Is this the case? Do most teams do this or is the suspension supplied by the chassis manufacturer? If they do, what can the teams change change set-up wise?
Any help would be a great help.
Thanks!
Scuderia_Russ
Re: Formula 3 regulations
I know that at least two of the top teams fabricate some of their own suspension parts. I've no idea what the current regulation framework allows though.
"Whether you think you can or can't, either way you are right."
-Henry Ford-
kreuzberg
kreuzberg
Thanks for the reply Russ.
Do you happen to know what parts they make?
Scuderia_Russ
Just wishbones as far as I know.
-Henry Ford-
