when u turn ur engine off whats that clicking sound?
adam2007
adam2007
u know when u turn ur engine off car, sometimes after 5mins u hear that clicking noise whats that? i heard maybe a EGR valve but not sure any idears? i have heard it on loads of random cars in carparks when walking past
xpensive
xpensive
214
Re: when u turn ur engine off whats that clicking sound?
adam2007 wrote:u know when u turn ur engine off car, sometimes after 5mins u hear that clicking noise whats that? i heard maybe a EGR valve but not sure any idears? i have heard it on loads of random cars in carparks when walking past
If you drive a Koenigsegg, like I do, that's the typical sound after the aluminium engine-block has adapted its
thermal expansion to the carbon fibre body, when the anti-torque pins lock into place.
tarzoon
xpensive wrote: If you drive a Koenigsegg, like I do
can you explain this a bit better?
CMSMJ1
CMSMJ1
the engine "ticks" as it cools down. Just the metal relaxing after a good session.
My Koennigsegg does't tick as much as my Bugatti Royale...
:shock:
IMPERATOR REX ANGLORUM
xpensive
xpensive
214
Christian von Koenigsegg built me a special edition, called CCX^2, don't know xactly what he meant by "squared" though.
tarzoon
koenigsegg^2 =
1 engine
4 seats
16 wheels
1 steering wheel
4 pedals
1 handbrake
4 deca-whatever-dral doors
9 mirrors (1 internal, 4 external) - sorry about my maths here, still trying to understand it :)
and it goes on
Pandamasque
That's even more annoying if you have a time machine like I do. I ticks all the bloody time. #-o
donskar
donskar
If this sound is NOT the heated metal cooling (it probably is), then it could be the fuel system releasing pressure.
Giblet
Giblet
In some cars you hear oil dripping onto the shallow part of the oil pan as well, which is a louder rhythmic clicking.
xpensive
xpensive
214
tarzoon wrote:koenigsegg^2 =
1 engine
4 seats
16 wheels
1 steering wheel
4 pedals
1 handbrake
and it goes on
I don't know, perhaps Christian was referring to the driver? :(
alexbarwell
alexbarwell
If its got 16 wheels, we might have seen it on Thunderbirds.
The ticking on mine is usually the exhaust cooling down, there are a couple of valves that motor shut after a while, but the constant pink-pink noise is the exhaust - when hot the original used to just tap on the rear valance...
I am an engineer, not a conceptualist :)
Giblet
Giblet
Mine lets out a sigh of exasperation and asks me not to drive anymore.
alexbarwell
alexbarwell
Or its the sound of all the loose bits of metal falling back into the sump...
Giblet
Giblet
My loose 'bit of metal' was the valve head, that had broke off when the timing belt snapped loose, as the piston crashed into the open valves.
I never found the valve head, but the hole in the side of the block, and the top of the piston looking as beaten as an anvil was a clue as to what had happened.
I love Honda engines, bit those timing belts are whores if you don't change them regularly.
ISLAMATRON
The've switched to timing chains now havent they?
