Why is unsprungmass negative?
Marst
Marst
Would anybody be kind enough to explain in what point unsprung mass has negative effect on race car dynamics. Thanks.
Rogue230
Rogue230
Don't want to go off half-cocked
I'll post an answer over the weekend. :wink:
Rogue230
Rogue230
Delayed, sorry
Unsrung mass has the effect of transfering road-shock to the car. It has inertia and doesn't want to respond to changes in the road.
Also, it slows the tires downward return to the pavement causing a potential loss of contact with the road.
Consider a go-cart; All mass is unsrung and all road irregularities are tranfered directly to the car.
If it were possible to have 0% unsprung mass the tires would quickly respond to road changes and return downward without delay giving a virtually perfect ride.
Seeing as perfect isn't possible, minimizing unsprung mass is highly desirable.
Micky
Micky
What exactly is unsprung mass?
Rogue230
Rogue230
Sprung vs unsprung mass
Sprung mass is everything riding on the springs; the body, engine, trans-axel.
Unsprung mass is that which the springs ride on; tires, wheels, out-board brakes.
Some parts are a mix; A-arms are 50-50. Half sprung and half unsprung, effectively.
