SimpleMind wrote:I've also read that by using wingtips to create vortices the gap between then sidepod and the ground can be sealed (because of the turbulence?) alowwing better effect from a shaped underside.
When ground effects were still being developed, it became obvious that air could "leak" in from the sides, and ruin all that effort. So "skirts" were used, until the rules outlawed them. So that problem of air leaking from the sides degrades downforce, but those wonderful and creative engineers have found partial solutions. Please examine the following picture.
Now, I would like to define the sidepod as being two parts, upper (where the "Petronas"is, and lower (below "Malaysia"). If you look at the entire lower sidepode shape, it starts narrow, widens, then narrows again. The air accelerates along this area, producing a low pressure area. Now, just below that is the flat floor, and note the sharp lip. That's important, because air does not like flowing past sharp corners. Air likes rounded corners.
Below the flat floor is the area that is important, where as much as 50% of the car's entire downforce is generated. It too is low pressure.
Now, if that narrowed sidepod section wasn't there, then the air pressure would be higher, and want to migrate from the sides of the sidepods into the bottom of the car. But it doesn't want to, because the air pressure along the lower side of the sidepod is low, and as well, that sharp lip on the floor really seals the deal by making it very difficult for air to migrate from top to bottom.
