Hi!
How do they adjust suspension geometry on a racecar ?
I mean camber, toe and castor ?
Can anyone show me a picture ?
normally you do it by shims ,as this is a definte adjustment.woohoo wrote:Hi!
It is worth remembering that alterations in camber angle will also need readjustment of toe (in) and it can result in a need for longer steering rack end rods if major camber changes are made. Adjusting caster can result in a change in steering angle due to possible variation in wheel base.speedsense wrote:Camber- As was mentioned,adjusted by the upper arm length, byway of using plates inserted just slightly inboard of the upper a arm connection to the upright
caster- adjustment is made by one of two ways or combination of both, the upper a arm upright connection is moved towards the rear of the car, along the long plane, by shortening one leg (usually the rear most one) of the upper a arm where it connects to the chassis, pulling the upper ball joint toward the rear. opposite on the lower one, (shorten the front arm connection)
Toe- The front is adjusted by the length of the steering arm (tie rod) that comes out of the steering rack. Shortening the tie rod causes toe in, lengthening the tie rod causes toe out. The rear also has tie rods (not for steering however) and toe adjustments are similar in respect, though most are located at the rear most point of the upright, so for toe in they would lengthen it.
Depends on upright design and location of the steering knuckle, some designs camber change does not effect steering rod length.autogyro wrote:It is worth remembering that alterations in camber angle will also need readjustment of toe (in) and it can result in a need for longer steering rack end rods if major camber changes are made. Adjusting caster can result in a change in steering angle due to possible variation in wheel base.speedsense wrote:Camber- As was mentioned,adjusted by the upper arm length, byway of using plates inserted just slightly inboard of the upper a arm connection to the upright
please..where is the lower wishbone attached to the upright on your picture?DaveKillens wrote:
Although this is not a Formula One suspension, it displays the multitude of adjustments available. Every ball-end is adjustable, and that's only the obvious. In racing, it is desirable, no, it is essential that all suspension parameters can be altered. In fact, teams have been known to construct A-arms of specific and different dimensions to suit changing conditions.
The example displayed above is very generic for most racing applications. It is easy to work on, and to adjust something, just a wrench is required. In Formula One, since the stakes and rewards are much higher, parts are not as easy to work on, and in many cases, to change a suspension parameter parts have to be swapped out. But the systems all have one thing in common, all suspension parameters can be altered.
