I’m interested in rigging up an on-board camera for my car (SLK). Has anyone here done this on a road car?
My thoughts are that it would be easiest to mount the camera on the dashboard behind the windscreen and there are suction pads for sale that could do that job. However, I’d really like to mount it further forwards and lower down to get a better sense of speed. (like the French film “rendezvous” ). It should be easy to probably strap it to the radiator grille.
I’m thinking of putting the camera in a plastic box with a Perspex window. That would need something to regularly clean the window of dirt. Perhaps a rotating disc with a wet sponge/rubber wiper? I’d have it continuously very slowly turning, powered by a small electric motor (avoids control electronics). Water could be supplied by diverting the headlamp washers (manually fired by the driver), or a continuous drip feed from a bladder (I have one of those in my greenhouse!).
Vibration would be a big issue. I was recently given a “Flip” solid state camera so don’t need to worry about movement causing problems with a disc system. I wonder how much vibration would spoil the image? A firm fixing would stop the camera wobbling, but would there still be vibrations after that?
I’d also need to run a microphone line to the exhaust to get a decent sound. I think the flip is mono, otherwise I’d run a left channel to the exhaust, and a right channel to the engine bay.
Any thoughts/ suggestions /tips are most welcome!
