Hey, I'm currently building a single seater racer as a college project, Formula Student. My main area of the build is Braking System Design. I am having problems with the design of a brake overtrave switch/ Circuit.
B7.3.1 A brake pedal over-travel switch must be installed on the car. This switch must be installed so that in the event of brake system failure such that the brake pedal over travels, the switch will be activated and will stop the engine from running. This switch must kill the ignition and cut the power to any electrical fuel pumps.
B7.3.2 Repeated actuation of the switch must not restore power to these components, and it must be designed so that the driver cannot reset it.
B7.3.3 The switch must be implemented with analog components, and not through recourse to programmable logic controllers, engine control units, or similar functioning digital controllers.
I have been told to use a latching relay to brake the circuit, with a reset switch away from the driver. I am unsure where to start so any advice would be greatly appreciated.
