Birel99 wrote:I assume that increasing preload will see the tires reach their 'optimum' slip angle sooner in the corner? But then reduce grip on the exit of the corner?
How are you coming to this assumption?
Personally I'm not a huge fan of screwing with preload unless you really have a good feel for it and a need. Just another non-linearity you're throwing in.
If you preload one axle, you're basically just putting the majority of the roll stiffness on that axle until you overcome the preload and the springs & bars start moving again.
So, if you were to preload the hell out of the front, I'd expect to have a lot of initial front axle load transfer... and generally numb the on-center / initial turn-in response.
