Metric vs Imperial units
segedunum
segedunum
xpensive wrote:Intersting measurement that, 760.643 mm, but with a +/- 2 mm tolerance...anyone of my designers putting that on a drawing would be fired on the spot!
It's a rather interesting disconnect in precision............ I had no idea things were quite that bad.
Reason: Split from Flexible wing thread
xpensive
xpensive
214
Re: Flexible wings controversy 2010
But it is seg - take a look at that table defining the front wing center-section's profile - to the micron!
xpensive wrote:But it is seg - take a look at that table defining the front wing center-section's profile - to the micron!
+/-2mil.. :lol: :lol: :lol:
thats what happens when UK boffins can only think in inches and the whole --- is translated to french and metrics ...not the first time not the last to see a machinist cry unable to do his work..and wasting days....
xpensive
xpensive
214
I don't know marcush, I simply cannot believe that any F1 engineer in the UK would work with anything but metrics,
but Ross Brawn on the other hand...? :lol:
Pup
Pup
50
Bah. I'll take feet and inches any day. We should switch everything to base 12.
xpensive
xpensive
214
Right, most folks with six fingers on each hand would probably agree.
mep
29
Maybe this explains why french people can only count to sixty and then start to calculate.
60 soixante
70 soixante-dix (60+10)
80 quatre-vingt (4*20)
90 quatre-vingt-dix (4*20+10)
autogyro
autogyro
mep wrote:Maybe this explains why french people can only count to sixty and then start to calculate.
60 soixante
The French thing goes back to the establishment of the prime meridian at Greenwich.
Have you ever tried navigating in metric?
mep
29
They could have used a system based on 10 for the time also.
Would make some things easier.
Its no problem to navigate then with it.
WhiteBlue
92
Pup wrote:We should switch everything to base 12.
What is the rational behind such an alien proposal? Do you have six fingers on your hand?
High cultures like the Romans have been using decimals for over 2,000 years and the positional decimal Hindu-Arabic system - which we use - is now more than 1,200 years old. More than half the earth population is using a decimal system. Further the international SI unit system which was created by modern scientists and engineers is based on the positional decimal system. To make changes to that sounds like a very strange idea.
I think you'll find that the UK is metric in all but name so far as engineering is concerned.
The only areas that are still imperial are road use (miles and miles per hour - fuel is already sold in litres) and beer.
Some older types still use feet/inches and pounds/ounces.
The rest is just about always metric - which is only right. Imperial is a dog's breakfast of a system.
And the funniest thing is that much of it was based on "English" units that were introduced by the Normans or were reused Roman systems. Some Anglo-Saxon remainded but that was often linked to the Roman systems.
All good fun...
Jersey Tom
Jersey Tom
Re: Metric vs Imperial units
Personally I'm a big fan of Imperial units.
1) They're easy.
2) When all your machine shop equipment and tooling is in Imperial units, that's what's practical.
RacingManiac
RacingManiac
Jersey Tom wrote:Personally I'm a big fan of Imperial units.
1) They're easy.
Ditto, but now I have to use metric becuase I work in the automotive supplier chain now....
Its weird, I learn metric as a kid in Taiwan, used metric throughout schools in Canada(still remember the dread that when the prof says there will be question in english unit). Yet I did all my FSAEs in imperial, uses AN/Mil-spec stuff in imperial, and learn all my machining in imperial. So now when I am designing stuff, I think in inches/psi because thats how I make things...Its hard to change back.
imightbewrong
imightbewrong
60 soixante
What is your source on that if I may ask? Can find nothing on it here at least
http://en.wikipedia.org/wiki/Vigesimal
xpensive
xpensive
214
Wtf is this, metric vs imperial, as if it was some kinda beauty contest? Must be Tomba's idea of a practical joke! :lol:
