raymondu999 wrote:To that extent then, how would a team like Virgin test their suspension geometry etc?
they can/would go to an institution which offers test rigs, if they do´t have their own ones.
For a 4 post-Rig this could be Multimatics/Dynamics in the U.K. , on top of the data you would get DaveW´s opinion/advice for free with it, if you are prepared to listen.
Not sure who offers K&C test rigs in the U.K., Cranefield maybe, Lotus Engineering I´m quite sure has one. But there will be different places where you can go.
Toyota Motorspot would have both, plus other test rigs, and is open to rent them out.
It depends of what you want to test for, and how you discribe "performance".
A K&C test in simple terms, is holding the car steady/fixed, while a plateform under the tire(s) can be moved in 3 directions to simulate the tyre/road interface and the forces which are generated in the tire contact patch.
Then you can measure, the changes in your toe, camber and caste values and the deflection in your components (wishbones, uprights, wheel bearings, rims !!!, pick up points etc.) It´s a quite realistic test, and you will be surprised more often then not, to see what´s actual happen in your suspension parts, when they are subject to real world loads.
some examples:
[youtube]
http://www.youtube.com/watch?v=rEJH0I2m60Q[/youtube]
http://www.tuev-sued.de/uploads/images/ ... catala.pdf
some ideas about the cost of such tests.
http://www.morsemeasurements.com/sitebu ... amples.pdf
