Hey all. Just wondering the above question, as it seems that there are a few setup portions that are counterintuitive. For example weight dist. By moving weight forwards, it increases forwards traction. Maybe true in slow corners, but in the fast stuff, wouldn't that increase the lateral loads that have to be moved by the tyres? And hence create understeer?
Then rearwards bias creates better turn in? Maybe when you're braking+turning at the same time, sure, but otherwise shouldn't a forwards brake bias increase the vertical/normal load on the fronts and create better grip for turning in hard braking zones?
I could go on, but you get the idea. Any takers?
