I've recently come up with an interesting idea for the gearbox. I'll try to get the drawing I made on the site, but I don't know how. I'll try to describe it. It has two stepped hollow cones(black) with hollow bearings(brown) on the inside. Along the outside of the cones are the gears, one cone with fixed gears(Green), the other with sliding gears(red) that are selected by a simple slider(yellow). The inside of the cones have vanes on them, doubling as a pump for the atf fluid. The fluid flows thru the hollow bearings and thru holes beneath the gears and thru a filter(blue) if needed.
I'm just wondering if this could be made into a practical transmission. The pic really helps, I'll keep tring to get it to work.
