Front wing airfoil
rohit_8481
rohit_8481
Front wing airfoil
Could some one help me out with what airfoil sections are used in the front wing.. Apart from the restricted bit that is... It's for my masters project.. I'm currently trying to go with a GAW-1... Help would be much appreciated.. Thank you...
PNSD
PNSD
Re: Front wing airfoil
Teams generally have their own optimized profiles but I guess low reynolds number/high lift airfoils.
rohit_8481
rohit_8481
well the project is actually the optimization of a front wing. But i need a base airfoil to begin with.. Thanks...
PNSD
PNSD
Im afraid I cant help there. The GAW 1 isnt too bad, i think a few teams did use it maybe in the 80's so you have a good base there.
rohit_8481
rohit_8481
Thanks a tonne... i've found a couple more.. an eppler 423 and a benzing 153-175...
countersteer
countersteer
Jersey Tom
Jersey Tom
Does it really matter what airfoil profile it is? Never going to be an exact, current F1 spec profile anyway.
If this is for your Masters degree, I would think it much more important that the thought process and project structure be good, as well as the actual computational approach and validation. The specifics of whether it's a Benzing or NACA profile or what have you isn't really critical I wouldn't think.
http://www.benzing.it/enrico.profili.htm
only single profiles unfortunatelly...
mep
29
Check this out:
http://www.mh-aerotools.de/airfoils/javafoil.htm
You can make multiple profile wings also.
rohit_8481
rohit_8481
Thanks a lot guys.. it helped a lot....
