The current regulation forbitds any aerodynamic action done by movements of the pilot but... the exhaust gases could be routed to any wing of the car that makes downforce as default. But at high speed thus high rpms and increased gas flow in the exhaust, with a clever design, the gases could be routed to the front of the wing so the airstream around the wing is minimized or deviated in order to minimize or even neutralize the downforce action of the wing and then minimize the drag.
Hot gas is a low density gas and it can change the laminar flow of a wing into a more turbulent flow thus reducing the drag of the leading edge and reducing the downforce.
It is like a F-duct but activated by the hot gas flow and not by a pilot movement. This could be a boost in all the straights since the use of the ARW is very limited by the 2011 regulation.
This could be the principle of the solution applied by Renault but front exit exhaust are not the ony way to apply this technique since there are, or could be, other wings to apply to...
And now I remind the early drafts of the F150 with additional sidewings on the engine cover, a place very close to exhausts...
This could be even applied to the Rear Wing as the traditional F-duct.
What do you, gurus think about this?
Regards
Oki
