Air Density trade off
Callum
So a friend and I were having a conversation...
At lower altitudes the air is more dense, providing more power for the engine and more downforce for a given speed.
At higher altitudes the air is less dense (and possibly cooler),giving less power to the engine but also less drag.
Now i know that drag is Fd=1/2.rho.A.v^2 showing that it is directly proportionate to air density. What is an equation for engine power which includes air density?
Getting to the crux of the matter... Is there an optimum altitude for a given car to race at presuming that the lower track and higher track are exactly the same?
Ciro Pabón
106
Re: Air Density trade off
Good question. At dynos they have been calculating it for ages. It's a bit complicated. I use this site:
http://wahiduddin.net/calc/calc_hp_dp.htm
Diggin deeper than usual into the site, I find that the equation to determine power in an engine is, "according to SAE method J1349 Revised AUG2004" (all hail burocracy! It sounds as if you don't use it, the Feds will get you...).
Where:
cf = the dyno correction factor
Pd = the pressure of the dry air, mb
Tc = ambient temperature, deg C
This equation is valid only for 15 to 35 degrees celsius and pressures between 900 and 1050 mbars. What I see in it is that Pressure and HP are correlated directly. Temperature and HP go as an inverse square root.
In english, the lower you are, the more power you have and, also, the cooler the night, the more power, but not that much.
So, the fastest races in the world, are in a Finland beach in the middle of a winter night (avoiding the reno! wow!).
There are more tricks, I should have assumed (darn mechanical engineers!): relationship between Altitude and Pressure is quite complicated, because this is not your everyday pressure but the "mechanical engineers pressure".
Read here for more data. It gives you also a calculator of density, pressure, full of moles and bars and Torricellis and whatnot: http://wahiduddin.net/calc/density_altitude.htm I confess I skipped that part.
Actually, what you can really do is to go to this site to know the data you have to input to get a real information on how much power your car actually gives you (you have to know the altitude of your city only).
http://weather.noaa.gov/international.html
Pick your country and beloved town from the lists you'll see and, armed with the figures you'll get, click on the first link I gave, enter the data and presto.
If I try to use 29.7 inches of mercury, a dewpoint of 15 degrees celsius, and 20 degrees celsius of temperature, kind of spring night, I get 100.8% of horsepower, in a cold night in Cartagena at a pleasant 0 meters over sea level. Nice motto: "Cartagena, more than 100%".
Now, at 2000 meters, in the outskirts of Bogotá, I get 75% of HP, keeping constant the other data.
At half way the altitude, at 1000 meters, in Cali, you get 87.5% of your engine. So, I'd say from these three points that power is roughly proportional to altitude.
So, I happily conclude that both effects of altitude, drag and power, should cancel each other, assuming you're right in the thing of "drag proportional to density" and, rest assured, somehow you'll find that also you have to take in account a "mechanical engineers drag", which is not your ordinary drag.
OF COURSE, I assume this relationship also depends on a freaking high number of other things, as that in Cali this night I am at a happy 25 degrees, while in Bogotá the night is at 12 degrees and people there are freezing their butts because dew point is 10 degrees, and it all depends on altitude, etc., etc., etc., but please, spare me the details.
I guess people here can tell you if you're marginally faster at an oval track in the Dead Sea or in a street course in Tibet, but I give up. I've learned enough and I do not discuss that kind of things if I don't have a rum bottle at hand.
As some of us reside in a rough country, probably other people could comment on the effects of altitude on engines. I can attest that driving a non injected underpowered car in this country is an exercise in self control, at more than 3000 meters.
And when I say self control, I mean self control. When I was young I had to walk through snow to go to school, young man.
Ciro
hollus
If drag and power both change linearly with altitude, the car will still be faster at lower altitudes, as for most of the lap it is not drag limited, and it will get faster to the speed where it is limited.
And then there is downforce, which goes up and up and up as altitude goes down.
In most cases, the majority is below the average.
Tim.Wright
330
That explains the reason behind Red Bulls adjustable ride height system :wink:
riff_raff
riff_raff
Depends on the type of engine. If the engine is turbocharged, the question becomes more complicated.
Commercial jet aircraft fly at altitudes above 30,000 ft for a very good reason. It has to do with lift/drag, air density and temperatures, and engine cycle pressure ratios.
A: Start with a large one!"
volarchico
volarchico
riff_raff wrote:Depends on the type of engine. If the engine is turbocharged, the question becomes more complicated.
The major reason commercial jet aircraft fly at the altitudes they do is because that is the design altitude of the engine for best specific fuel consumption. Even saving less than 1% fuel consumption becomes huge savings for an airline. Their max power, though, like already mentioned is still at the lowest altitude, coldest day.
As far as racing goes, I agree with hollus (and Tim!) that a car will lap faster at lower altitude. If drag were more important than downforce, we'd seen cars designed VERY differently.
marekk
marekk
Depends on track.
I can imagine that Monza (and all ovals) will be quicker if transfered to Bogota, Monaco rather not. I agree most of current F1 tracks are downforce limited, that's the reason why RedBull and not HRT or Virgin is WCC.
Looking at Ciro's eqaution of dyno correction factor, engine's power drop is less then 1.176*presure_change (assuming temp=constant). On the other hand, drag is drag_ coefficient*pressure*V^2, and i'm quite sure drag coefficient for F1 car is more then 1.176 (probably around 1.4-1.5).
shelly
shelly
136
drag is (surface*drag coefficient*density*v^2)/2.
The product surface*drag coefficient (Scx) is not that high (1,4-1,5) for a F1 car; I think it is slightly lower, in the range of 1.2, maybe lower for high speed tracks
twitter: @armchair_aero
marekk
marekk
shelly wrote:drag is (surface*drag coefficient*density*v^2)/2.
Agree. Did the math and Scx of < 1.2 looks right.
I was totaly wrong anyway (as usual, when using intuition instead of real numbers).
Using both equations and standard atmosphere model for air pressure/density, engine's power drop rate is significantly bigger then drag reduction rate. Without some sort of intake compression cars will be slower with altitude, on any track :oops: .
