adam2007 wrote:why do some sports cars and formula one cars use push/pull rod. y not use normal car suspension with the spring and stut? what advantages do you get as why they use it? or is it manily down to its better at being packaged?
Packaging and the ability to design in movement ratios and other things (like 3rd springs) also it gives them a chance to move stuff out of the air-flow.
Presumably, they can also feed the suspension loads into stiffer parts of the chassis.
Race teams can generally afford to design, make and maintain all those links. They can have expensive dampers that work within those constraints.
Road cars and a different set of priorities, cost and long life being pretty high up the list (also they generally have the height/space to use the systems they do without a big penalty).
