Ferrari 125
Active: 1950 - 1951
Chassis: Two elliptic section longitudinals and tubular cross members; Aluminium single-seater body
Drive: Rear
Clutch: Dry, single-plate clutch
Gearbox: in block with engine, 5 gears + reverse
Brakes: Drums all round with hydraulic control
Front susp.: Double wishbones, double triangles, lower transverse leaf spring, Houdaille hydraulic dampers
Rear susp.: Swing axle shafts, thrust bars, torsion bar and Houdaille hydraulic dampers
Differential: conventional differential
Weight: 710 kg with water and oil
Wheels: Spoked
Length: 3,685 mm
Width: 1,400 mm
Height: 1,025 mm
Front track: 1,278 mm
Rear track: 1,250 mm
Wheelbase: 2,160 mm
