Ferrari 166 F2
Active: 1950 - 1952
Chassis: Tubular longitudinals and cross members; Aluminium single-seater body Drive: Rear Clutch: Dry, single-plate clutch Gearbox-control: Front gearbox Brakes: Drums, hydraulic control Nr. of speeds: 5 + reverse Front susp.: Independent, double wishbones, lower transverse leaf springs Rear susp.: Live axle, lower longitudinal leaf springs Front track: 1,255 mm Rear track: 1,200 mm Wheelbase: 2,420 mm Weight: 700 kg empty
