McLaren M19C
Active: 14-05-1972 - 03-03-1973
Team: Ralph Bellamy (TD)
Drivers: Denny Hulme, Peter Revson, Jody Scheckter
Chassis/body: aluminum monocoque
Suspension (fr/r): wishbones, coil springs over dampers, anti-roll bar
Steering: rack-and-pinion
Brakes: vented discs, all-round
Gearbox: Hewland DG 300 5 speed Manual
Drive: Rear wheel drive
Weight: 560 kg / 1234.6 lbs
Wheelbase: 2540 mm (100 in)
Track (fr/r): 1600 mm (63 in) / 1575 mm (62 in)
Configuration: Ford Cosworth DFV 90ยบ V 8
Weight: 168 kg / 370.4 lbs
Construction: aluminum block and head
Displacement: 2.993 liter / 182.6 cu in
Bore / Stroke: 85.7 mm (3.4 in) / 64.8 mm (2.6 in)
Compression: 11.0:1
Fuel feed: Lucas Fuel injection
Power: 450 bhp / 336 KW @ 10000 rpm
