Benetton B193B
Active: 1993
Team: Benetton Formula Ltd
Designers: Ross Brawn, Rory Byrne
Drivers: Michael Schumacher (5), Riccardo Patrese (6)
Chassis
Front suspension: double wishbones, pushrod, twin spring/dampers
Rear suspension: double wishbones, pushrod, twin spring/dampers
Suspension dampers: Benetton active
Wheel diameter: front: 13 inch
rear: 13 inch
Wheel rim widths front: 11,5 inch
rear: 13,7 inch
Tyres: Goodyear
Brake calipers: Brembo
Brake discs: SEP
Brake pads: SEP
Steering/ Benetton
Radiators: Secan
Fuel tanks ATL
Battery: Ford
Instruments: Ford
Gearbox: Benetton six-speed transvers semi-automatic
Driveshafts: Benetton
Clutch: AP
Dimension
Formula weight: 505 kg
Fuel capacity: 200 litres
Type: Ford HBNo. of cylinders: V8 (75°)
Fuel and oil: Elf
Sparking plugs: Champion
Electronics Ford electronics
