Ferrari F93A
Active: 1993
Engine: Ferrari 3500 (E2 A - 93); 65° V12
Fuel & Lubricant: Agip Petroli
Unitary and Total Displacement: 291.49/3,497.96 cc
Max. Power Output: approx. 700 bhp
Timing Gear: 60 valves (48 from German GP qualifying trials, from Italian GP itself)
Fuel Feed: Weber-Marelli digital electronic injection
Ignition: Champion 10 mm spark plugs, electronic; Magneti Marelli static
Transmission: Rear-wheel drive, semi-automatic, transverse 6-speed gearbox + reverse with electronic management, limited-slip differential
Chassis: Composite: carbon-fibre honeycomb
Front Suspension: Independent torsion arms, electronic actuators
Rear Suspension: Independent torsion arms, electronic actuators
Brakes: Ventilated carbon-fibre discs on all 4 wheels
Length: 4,350 mm
Width: 1,995 mm
Height: 995 mm
Front Track: 1,690 mm
Rear Track: 1,605 mm
Kerb Weight (with water and oil): 505 kg
Tyres: Goodyear
Wheels: BBS O 13" (front and rear)
