Dukeage wrote:Would it be possible (and I guess the answer might be no) to dye the whole tyre a different colour? One option that would require a bit of electronic hackery that I have thought of is green LEDs at the tip of the nose cone - this could make it easier to show that on the timing, which would be a great idea. There are already more complex electronics in the front wings - the variowings.
Good point. I'm growing in my frustration with F1 which is sliding from what, in my opinion shall be. If in edurrance is possible to lit some LEDs on the side of the cars, why F1 is using only a c**p dye? There are other examples but I will stop here. At least they should do it manually, by somebody at the exit of the pitlane, updating the graphics and live timing (similar with old letters B and M for the two tire suppliers).
