DChemTech wrote: ↑11 Feb 2022, 10:10
AeroDynamic wrote: ↑11 Feb 2022, 10:01
DChemTech wrote: ↑11 Feb 2022, 09:52
What are you on about? Wheatley never asked Masi to break the rules and only let a few cars pass. He said:
"Obviously those lapped cars, you don't need to let them go right away round and catch up with the back of the pack"
Which is correct. With only a lap to go, a gap between the leaders and lapped cars of some 10 seconds is enough to prevent them from getting in the way. But in no way does the above imply to only let -some- cars through. Wheatley's request was no more outrageous than Toto saying "No SC please" or anything along those lines. When I talk about Toto playing games with the FIA, I mean that they strongly lobbied for mid-season rule changes with respect to the wings and pit stops, and incredibly,
succeeded. Talking about a team influencing the season.
It isn’t unheard of for rules to change mid season though. Do you forget the engine rules change mid season in 2020?
I did not forget that, but I do not have enough information on what actually transpired there to classify it as being a rule change, or a rule clarification. If the rules state an absolute limit of something, e.g. a maximum fuel massflow, and a new test is introduced because some teams may be exceeding the limit without detection, that's no rule change. It's a new way of enforcing an existing rule. But with the 'flexing' wings, no absolute limit was stated - the only limits
were the tests, and then changing the tests means changing the rules. Which should not happen, and certainly not based on the requests of a participating team.
For example, if the rule stated
Part X cannot deflect more than 3mm under any condition, which is tested by applying a load Y under stationary conditions, and load Y is increased or the way of application and measurement is changed at some point, no problem, the rule itself remains unchanged. The designers designed for a max. deflection of 3mm, and should not exceed that.
If the rule stated
Part X cannot deflect. This is tested by applying load Y under stationary conditions and measuring whether the deflection does not exceed 3mm , and this is subsequently changed to
measuring whether the deflection does not exceed 3mm , the definition of what counts as deflection, and hence the rule itself, is changed. And that is a problem. The designers designed for a max. deflection of 3mm, and now suddenly the criteria change such that their perfectly legal design becomes illegal. Instigated because a competitor didn't like the degree of deflection they noted visually.
It wasn’t a clarification. It was a rule change. It didn’t benefit Mercedes’ at all, as they had the most powerful advantage of extremes between qualifying mode and race mode. This massively benefited Ferrari, Honda, and Renault. Both in development costs, and on making Mercedes’ are more reachable target.
The rules changing mid season against Mercedes and nobody was complaining about that being bad.
The game is the game. In cases like the tyre war, Ferrari knew something was up with the contact patch but didn’t complain about it until much later and were threatened.
Mercedes made a complaint about the wings, and F1 clearly agreed the wings should not be moving as much as they were, the load tests were designed to police that kind of movement. Just because the teams figured out how to pass the test but achieve the same aim, doesn’t mean what the wing does is ‘legal’ just means it legally passed the test. It is literally the same thing as the Ferrari engine saga: it passed the sensor / tests, but what it DOES is not correct with the rules.
The rules have stayed the same in this case, the only difference was the mandated test to police the rules changed.
This is no different than F1 supposedly adding additional sensors to Ferraris power unit in ‘19 - same rules, more stringent tests to police it.
The actual engine mode rules was literally a change of rules in 2020, not a change of tests.
The pit stop rule change was a rule change though. But if you’re Mercedes’ and rules were changed against your advantage, why wouldn’t you do the same with a new team is at the front? And this is on the presumption that Mercedes’ in fact lobbied for a change, has any proof came out that this happened? According to Mercedes’ they seeked a clarification on their own equipment, and F1 themselves changed the rules?
