Ferrari F1-75
ryaan2904
ryaan2904
36
Re: Ferrari F1-75
Emag wrote:
18 Feb 2022, 14:30
Henri wrote:
18 Feb 2022, 13:53
It better top 2 in Barcelona timing laps
Laptimes are just about the most worthless piece of information you can extract from a testing session. It literally tells you nothing about how the car will perform because you have zero idea on what each team are doing and under what conditions everyone set their laptimes.
Historically, the top teams have always been on the top tho. Even when doing the long runs.
CFD Eyes of Sauron
Sieper
73
Re: Ferrari F1-75
Fer.Fan wrote:
18 Feb 2022, 17:45
JPower wrote:
18 Feb 2022, 17:28
https://preview.redd.it/d9oue3jjzli81.j ... 5639191836
That roll hoop inlet is tiny. Have to wonder what they saw in their data to go with the low cooling setup vs the centerline many of the other teams use.
the answer is higher downforce and more efficient car. Thats why Ferrari have small rollhop. They want more clean air to rearwing, to have more downforce. Cooling by centerline means more cooling is packed in centerline and rollhop is much bigger. Another reason the center of gravity is higher in center cooled cars. Cars have more weight higer up and that is not good for driveability in corners. On the other hand with center booling you kan have smaller sidepods and bigger undercat.
Plus Ferrari has no split turbo. That already makes the start off position/decisions for packaging different to Honda and Mercedes powered teams.
Henri
Henri
-6
Re: Ferrari F1-75
ryaan2904 wrote:
18 Feb 2022, 18:04
Emag wrote:
18 Feb 2022, 14:30
Henri wrote:
18 Feb 2022, 13:53
Barcelona testing has always been accurate
Emag
Emag
76
Re: Ferrari F1-75
ryaan2904 wrote:
18 Feb 2022, 18:04
Emag wrote:
18 Feb 2022, 14:30
Henri wrote:
18 Feb 2022, 13:53
Long runs are a different thing. You said you expect them top 2, and that implies being in the top 2 of the best times.
And your first point is not valid.
We have had teams leading testing sessions which didn't even brake the top 5 in the final standings.
jumpingfish
53
Re: Ferrari F1-75
Interesting angle.. looks fat :D
ryaan2904
ryaan2904
36
Re: Ferrari F1-75
Emag wrote:
18 Feb 2022, 18:09
ryaan2904 wrote:
18 Feb 2022, 18:04
Emag wrote:
18 Feb 2022, 14:30
I didn't mean "only" in long runs. I meant in the overall time charts, that even if the top teams are just doing high fuel-load, low engine modes, reliability runs (aka long runs), they've always maintained the status quo.
CFD Eyes of Sauron
ryaan2904
ryaan2904
36
Re: Ferrari F1-75
Sieper wrote:
18 Feb 2022, 18:08
Fer.Fan wrote:
18 Feb 2022, 17:45
JPower wrote:
18 Feb 2022, 17:28
Are we sure that Ferrari has no split turbo?
CFD Eyes of Sauron
JPower
JPower
43
Re: Ferrari F1-75
ryaan2904 wrote:
18 Feb 2022, 18:53
Sieper wrote:
18 Feb 2022, 18:08
Fer.Fan wrote:
18 Feb 2022, 17:45
Yes.
MTL79
MTL79
Re: Ferrari F1-75
Is there any indication that Ferrari's floor is just a presentation version?
Re: Ferrari F1-75
What if the bulges on the outside are just ducts and the radiators and heat exchangers are all packed by the gills. Then they'd be up to the gills in radiators.
gcdugas
Re: Ferrari F1-75
jumpingfish wrote:
18 Feb 2022, 18:24
https://cdn-1.motorsport.com/images/mgl ... -75-1.webp
And fast... look at it gain on the vehicle ahead of it. The closing rate is phenomenal.
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
Herr_Koos
Re: Ferrari F1-75
gcdugas wrote:
18 Feb 2022, 21:04
jumpingfish wrote:
18 Feb 2022, 18:24
That's true of any F1 car from any era compared to any road car.
Fer.Fan
Fer.Fan
Re: Ferrari F1-75
Binotto on new car. Thay can repack sidepods during seasong if needed;
“If you look at the body shape we have got, [it is] quite wide, certainly, we have not filled underbody the full space, so we have got flexibility certainly in the middle of the car, in the bodywork. It’s worth somehow the regulations have got most of the freedom.
“If you look at the regulations it’s quite [prescriptive] on the front wing, on the nose, rear wing but there’s much more flexibility around the bodywork but the way we have packaged our power unit that will leave us some freedom in the future if we do at least at the start if there are other directions that can be promising.”
wowgr8
wowgr8
29
Re: Ferrari F1-75
I highly doubt it's mid season. Ferrari aren't the type to bring a b-car or change a car around drastically mid season. If these sidepods don't work the change will come next year
Fer.Fan
Fer.Fan
Re: Ferrari F1-75
Fer.Fan wrote:
18 Feb 2022, 21:41
This interview shows that ferrari are unsure of their concept and are ready to act during the season. Sidepods are WIDE and draggy. Just compare to W13 and RBR18. Packaging of Ferraris PU, bodywork and sidepods, I am concerned…
[-o< [-o< [-o< [-o<
