McLaren MCL36
Tombola37
Tombola37
Re: McLaren MCL36
Lots of the car being covered in basic carbon panels in my opinion. Could be wrong but there are odd angles/notches/bumps all over it. Expecting a very different car come second test and race.
Emag
Emag
84
Re: McLaren MCL36
Brightened to pull out some details. Couldn't get much out of it, but I think there is a winglet on top of the "bargeboard".
_cerber1
261
Re: McLaren MCL36
f1rules
f1rules
597
Re: McLaren MCL36
interesting layout to help create outwash, see how much the upper element twist, and how the three upper elements closer to the endplate almost merge
Re: McLaren MCL36
McLaren has switched what I dub the Albatross front wing. Ferrari, Haas, McLaren, Alfa, all have similar front wings.
Re: McLaren MCL36
f1rules wrote:
21 Feb 2022, 21:30
https://pbs.twimg.com/media/FMJNRmrX0AU ... ame=medium
Birds twist their wing because it improves laminar flow, turbofan engines made a big step in performance when they started using 3d twisted aerofoils, if it's good enough for G.E. it's good enough for F1 :D
Re: McLaren MCL36
Mclaren's venturi inlet seems to go straight across.
KingHamilton01
Re: McLaren MCL36
Tombola37 wrote:
21 Feb 2022, 21:16
I agree with you on this, I think the fact they said they would be ready to adapt the car and keeping everything at launch very basic and minamum amount of parts made. They also mentioned that an update package is being made for the first race. Be interested to see if they manage to get any updates here for first test and if they can adapt major elements of the car for the second test that they want to see improvement in.
but they could turn up at start of test with some new part's that are different from what we have seen so far. Excited to see which route the development war goes down. I think most obvious places for development will be front wing, Venturi tunnel's, rear wing and diffuser.
McLaren Mercedes
Marc.W
26
Re: McLaren MCL36
SmallSoldier
SmallSoldier
479
Re: McLaren MCL36
New winglet behind the entrance to the Tunnels
Marc.W
26
Re: McLaren MCL36
SmallSoldier wrote:
21 Feb 2022, 22:29
https://i.imgur.com/3TxNWrx.jpg
Can see it a little better here
Marc.W wrote:
21 Feb 2022, 18:34
Is that a camera on the floor or something permanent?
https://i.imgur.com/jsN4zNe.png
The little bulge on the nose cone makes me think it's a camera of some sort
SmallSoldier
SmallSoldier
479
Re: McLaren MCL36
Marc.W wrote:
21 Feb 2022, 22:31
SmallSoldier wrote:
21 Feb 2022, 22:29
Marc.W wrote:
21 Feb 2022, 18:34
Could very well be… Seems an odd location to have a winglet and it been allowed
Owen.C93
Owen.C93
177
Re: McLaren MCL36
Maybe it's part of the rule that says you can have up to 4 strakes per side? Need to have another read...
Tombola37
Tombola37
Re: McLaren MCL36
f1rules wrote:
21 Feb 2022, 21:30
Looking at this image of the side pods there is a very defined angle where the vertical straight edge meets the shoulder of the side pod. Doesn’t seem right to me. Could we expect an undercut to come in as of Wednesday? This could be just a filled out basic panel fitted to disguise the true shape
Xero
32
Re: McLaren MCL36
Tombola37 wrote:
21 Feb 2022, 23:02
It's effectively there to replace the outwash effect of the old bargeboards. By using that space to package some cooling, it gives the car a strong downwash over the sidepod and into a very spacious rear floor area. None of these cars seem right, because it's a new formula, but this approach makes sense to me.
