I wonder if it’s something that be managed some with the shock valving and teams inexperience with ground effects are throwing them off.
Obviously it’s ultimately an aero issue.
11:09 Amazingly, no stoppages or red flags in this opening day! Apart from a slight excursion from Max Verstappen in the gravel, everyone kept it clean.
Okay so there's 2 different behaviours - the high speed porposising is resulting from an aerodynamic stall when the ride height drops - the ride height then rises allowing the air to reattach - the ride height drops and stalls... etc
So sounds like a lot of mechanical chassis issues to me.Dee wrote: ↑23 Feb 2022, 19:19https://the-race.com/formula-1/mark-hug ... trackside/
Hughes said all the cars have issues with it, including the fastest ones
he was on the softest tires, he probably should have been the fastest in sector 3!
