Mercedes W13
JPower
JPower
43
Re: Mercedes W13
west52keep64 wrote:
28 Feb 2022, 00:12
The rules are so prescriptive now, it's hard to really draw a definitive line between different aero philosophies. If you moved a few things around on the W13, is it really all that different from the MCL36?
The cars this year a different, but they are a far cry from the different aero concepts of previous years. They are all fundamentally part of the same very prescriptive formula now, and the differences between them are things all teams could adopt either during this season or in future seasons.
The idea that any team is married to a particular aero philosophy is a thing of the past.
Pretty much. Ferrari could change to an Alpine/RB/AT-style downwash fairly easily if they wanted to.
De Jokke
Re: Mercedes W13
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
232
Re: Mercedes W13
The car is fine. They are on the right track. The smaller the body of the car the better it is.
Ferrari is doing the opposite, but they are an exception because those sidepods are basically a big wing profile creating downforce. But I suspect this will come at a cost to drag and transient behavior.
Mercedes are okay. I don't see any dead end path for them, and having that slim car with that engine will still leave them as the fastest in a straight line. With the weight of these cars, theyre all going to be more or less the same in the corners; more weight for a little more downforce with lots of inertia. It's the straight line where the differentiator will be.
Unc1eM0nty
Re: Mercedes W13
zibby43 wrote:
27 Feb 2022, 21:18
As I stated previously, a side pod change really isn’t that difficult to execute for a top team. They pulled it off mid-season in 2018. Only thing they couldn’t do was move the SIPS.
With the 2022 budgets it might not be that easy
Unc1eM0nty
Re: Mercedes W13
27 Feb 2022, 22:45
It doesn't need to be a B-spec car to change sidepod. Cars are developed in small bits and pieces all of the time.
I think we are drifting away from the original speculation where it was said it would be "heavily revised".
I'm sure we will see refinements not only at the next test but thought the season. All teams will need to spend wisely though, they don't have a bottomless pits anymore, and it's early days as far as understanding their car in concerned.
Re: Mercedes W13
Unc1eM0nty wrote:
28 Feb 2022, 02:16
27 Feb 2022, 22:45
and why can't the Merc be heavily revised?
A lion must kill its prey.
f1316
f1316
84
Re: Mercedes W13
ringo wrote:
28 Feb 2022, 01:55
Actually if anything Mercedes is now the exception in retaining a “smaller is better” sidepod philosophy. Every other car, with the exception of the Williams, is now running larger sidepods than last year and significantly so for Ferrari, Aston Martin, Red Bull and Alfa.
The CFD analysis done on this forum seems to indicate that, as a baseline (I’m not talking about specific cars but the baseline small sidepod vs “dipped”) the small sidepod philosophy is actually higher drag. Is it a coincidence that Mercedes are said to be targeting lower drag with new sidepods fot Bahrain? https://us.motorsport.com/f1/news/merce ... n/8512038/
e30ernest
e30ernest
27
Re: Mercedes W13
I doubt any big changes they bring to Bahrain would be in response to anything they've seen from other teams at the moment. It would take more time to analyze, conceptualize and implement large changes so if they do come with large changes, those would have been changes that were in the pipeline long ago. So if the rumored big changes to sidepod design are true, then those would have been planned well before the Barcelona test actually began.
Small bits and bobs added or changed around the car would be more in line as a reaction to the test IMO.
cirrusflyer
Re: Mercedes W13
zibby43 wrote:
27 Feb 2022, 21:18
LM10 wrote:
27 Feb 2022, 18:52
27 Feb 2022, 17:33
The Merc mechanical bits are tightly packaged. They have room to grow the bodywork outwards to improve drag quite trivially...
Every significant change to the sidepod shape will require changes to the rest of the entire car as wider sidepods would mean a drastical concept change for Mercedes.
As Mercedes have already chosen their philosophy and built their whole car around it, we’ll quite surely not see a change to such extends. If they even decide to change concept, it will not be before next season until we see it.
They could have already made the change months ago.
https://www.motorsport.com/f1/news/merc ... 30693/amp/
Could they just make SP purly for aerodinamic reasons? Make tunnels to direct air where you like, no obstacles in the SP.
If flying were the language of man, soaring would be its poetry.
It's all about technology!
When you go fast, do not hesitate to go faster!
Re: Mercedes W13
What's impressed me is that the car is always collecting aero data, even without the big rakes attached. Mercedes have sensors on the floor, under the floor, on the rear wing, probably other places too.
It's like they are using the car as a full size wind tunnel model.
Interested to see what they bring to Bahrain as an update package.
OO7
OO7
171
Re: Mercedes W13
Just_a_fan wrote:
28 Feb 2022, 12:28
Yep, it is quite impressive. They also had sensors in the roll hoop intakes.
Re: Mercedes W13
OO7 wrote:
28 Feb 2022, 12:40
Just_a_fan wrote:
28 Feb 2022, 12:28
Yep, it is quite impressive. The also had sensors in the roll hoop intakes.
It's the kind of detail that shows you how well prepared the Merc was for that test. It does suggest they are a bit ahead in terms of preparation and readiness. Contrast this with the Red Bull which has clearly spent more time getting last minute parts on it despite their shakedown the day before Merc.
Stu
Re: Mercedes W13
Just_a_fan wrote:
28 Feb 2022, 12:28
That is something that a lot of them are doing, there are now some very small aero sensors that allow you to monitor surface pressures (and therefore airflow) without adding a great deal of weight or bulk. The big rakes allow them to measure the flow away from the surface (to test for correlation with CFD), the shapes of these have really evolved in the last few years!!
dren
227
Re: Mercedes W13
Just_a_fan wrote:
28 Feb 2022, 12:28
I really don't find it very impressive or surprising that Mercedes or any other team has an abundance of sensors on the car.
Honda!
Re: Mercedes W13
Stu wrote:
28 Feb 2022, 19:41
Just_a_fan wrote:
28 Feb 2022, 12:28
So far most have a few here and there. Mercedes even have them in the diffuser which none of the other teams appear to be doing.
