chrisc90 wrote: ↑14 Mar 2022, 21:20
SmallSoldier wrote: ↑14 Mar 2022, 21:17
Stu wrote: ↑14 Mar 2022, 20:25
There is implication in the phrase “must”, that is not there with “should”. It does not mention whether any sanction will be imposed; but the use of “must” is quite strong and leads to “I wonder what would happen if I don’t?”,when viewed in the negative.
Agreed… But, it could simply a fine, not related to what was posted in terms of “Sanctions”… Very different.
If the question is should Lewis get a fine, slap on the wrist or an e-mail stating he did wrong… I agree, he shouldn’t have missed the Gala if he was supposed to attend… If the question is if he should get any kind of penalty that will influence him on track (reprimands, points on his license, 10 second penalty, grid positions, etc)… That’s absurd.
The reason I included the sanctions section on there, is that I believe(d) that the sanctions section of the sporting code would be relevant to that document. Its a bit like a breach of the technical regs, and having a sanction from the sporting code or vice versa. It would seem relevant that a breach of the code, would be punished in the sanctions listed within that document.
You are making that assumption, nowhere in the document does it say that those Sanctions that you posted are related to the infraction… You are simply building a narrative.
If the question is should Hamilton serve some sort of penalty for missing the ceremony? I’m incline to say yes… Is that a fine, community service, an apology or something similar, not up to me to decide what would be appropriate.
But, to bring up sanctions related to behavior during a race weekend, that specifically mention that are imposed by Stewards, is mixing to separate issues… For starters, those Sanctions you posted are to be imposed by Stewards, there are no Stewards for a “Gala Ceremony”… Even from a common sense stand point, penalizing in a way that it can have an effect on a race weekend for something that happens outside of it, it’s absurd.
