Yes, it is the other way around. Red means Leclerc is slower, blue means Max is slower. Here you can see it.
Makes sense, shows that second that Verstappen gained in VSC.Wouter wrote: ↑31 Mar 2022, 22:51Yes, it is the other way around. Red means Leclerc is slower, blue means Max is slower. Here you can see it.
https://en.mclarenf-1.com/2022/gp/s8978 ... s/821-833/
I've been a fan since the 90's, I know exactly how tough the competition is between drivers fighting for the title. So far Charles seems to have kept his cool to score as many points as he can. He won't have not noticed Max tangling with Lewis last season.
In or after VSC? By the rule they are equal in VSC to before VSC and I can not see him gaining in VSC. So the difference needs to come from the lap once VSC ends.dialtone wrote: ↑01 Apr 2022, 00:05Makes sense, shows that second that Verstappen gained in VSC.Wouter wrote: ↑31 Mar 2022, 22:51Yes, it is the other way around. Red means Leclerc is slower, blue means Max is slower. Here you can see it.
I think he will not only have noticed, but studied how both handled them selves on and off the track, and remembered thing he will use to his advantage. He has already used Max aggressive passing to his advantage in the two races this year. It will no doubt make him a more sucesful and better driver.taperoo2k wrote: ↑01 Apr 2022, 16:02I've been a fan since the 90's, I know exactly how tough the competition is between drivers fighting for the title. So far Charles seems to have kept his cool to score as many points as he can. He won't have not noticed Max tangling with Lewis last season.
In. The rule states they need to drive to a minimum time assessed between each illuminated panels. Not that their distance needs to stay the same. VER was somehow able to pick up almost 1s during VSC.basti313 wrote:In or after VSC? By the rule they are equal in VSC to before VSC and I can not see him gaining in VSC. So the difference needs to come from the lap once VSC ends.dialtone wrote: ↑01 Apr 2022, 00:05Makes sense, shows that second that Verstappen gained in VSC.Wouter wrote: ↑31 Mar 2022, 22:51Yes, it is the other way around. Red means Leclerc is slower, blue means Max is slower. Here you can see it.
Where were they located when it ended? With such a big difference Lec was in a corner and Ves still on straight?
Rear ERS blinking red light (dry race) does not blink when harvesting. It starts blinking when not deploying (stopped deploying). Harvesting by MGU-K is activated only by the brake pedal and not when lifting of throttle. Number 16 was even harvesting when still on throttle by using both pedals together at some parts of track.codetower wrote: ↑29 Mar 2022, 23:03Were they genuinely not working, or did Max just assume they weren't working properly? Perhaps Charles wasn't harvesting when Max thought he should be.Dee wrote: ↑29 Mar 2022, 22:3914.3 says that rear lights must be working throughout but it says nothing about what happens if they are notkptaylor wrote: ↑29 Mar 2022, 22:13I saw the question earlier in this thread but never saw the answer. What do the regs say about Leclerc's rear lights being out for the first part of the race? Is this directly addressed in the regs? The F1 feed commentators talked about it and wondered if it might mean a penalty, but then they dropped it and never answered their own question. Had me wondering what the answer really is!
Ahh, thank you for the explanation!saviour stivala wrote: ↑01 Apr 2022, 18:46Rear ERS blinking red light (dry race) does not blink when harvesting. It starts blinking when not deploying (stopped deploying). Harvesting by MGU-K is activated only by the brake pedal and not when lifting of throttle. Number 16 was even harvesting when still on throttle by using both pedals together at some parts of track.
The assertion that the driver has to use the brake pedal to get MGU-K harvesting is not correct. The decision on harvesting when the driver is making any power demand is made by the ECU. If this were not the case then to get Honda’s extra harvest to work the driver would need to tap the brake pedal at between 20 and 40 Hz.codetower wrote: ↑02 Apr 2022, 01:50Ahh, thank you for the explanation!saviour stivala wrote: ↑01 Apr 2022, 18:46Rear ERS blinking red light (dry race) does not blink when harvesting. It starts blinking when not deploying (stopped deploying). Harvesting by MGU-K is activated only by the brake pedal and not when lifting of throttle. Number 16 was even harvesting when still on throttle by using both pedals together at some parts of track.
To clarify:dialtone wrote: ↑01 Apr 2022, 17:18In. The rule states they need to drive to a minimum time assessed between each illuminated panels. Not that their distance needs to stay the same. VER was somehow able to pick up almost 1s during VSC.basti313 wrote:In or after VSC? By the rule they are equal in VSC to before VSC and I can not see him gaining in VSC. So the difference needs to come from the lap once VSC ends.
That's quite literally gaining 1s during VSC, and the lap times also check out. Not sure the difference between your "1.4s moments after VSC was pulled in" and "sudden gap of only 0.8 almost immediately thereafter". Anyway...Juzh wrote: ↑04 Apr 2022, 00:35To clarify:dialtone wrote: ↑01 Apr 2022, 17:18In. The rule states they need to drive to a minimum time assessed between each illuminated panels. Not that their distance needs to stay the same. VER was somehow able to pick up almost 1s during VSC.basti313 wrote: In or after VSC? By the rule they are equal in VSC to before VSC and I can not see him gaining in VSC. So the difference needs to come from the lap once VSC ends.
Verstappen was 1.6s behind moments before VSC was declared, and he was 1.4s behind moments after VSC was "pulled in". This is almost nothing, you just can't expect a driver to be millisecond perfect on the restart (leclerc gifted him 2 tenths by being slightly too careful basically). So he didn't gain 1 second during VSC period as people make it out.
The thing that confused people was a sudden gap of only 0.8s almost immediately thereafter. What probably happened was leclerc misjudged VSC ending delta time, so he had to jump on the brakes to not go too fast (certain penalty), meanwhile verstappen behind did the opposite and came at him almost with full throttle, pre-empting VSC ending in a better way.
The rule states:Juzh wrote: ↑04 Apr 2022, 00:35On a different topic, how come this wasn't a penalty for magnussen? straight up crossing white line and then entering pitlane, yet nothing came of it. Remember how Tsunoda got hit with double penalty for crossing the line in austria 2021? This new race direction seems very inept.
Considering that Ricciardo's car was right in front of the pit entry line, Stewards decided that it was force majeure and decided not to award any penalty.d) Except in cases of force majeure (accepted as such by the Stewards), the crossing, in any direction, of the line separating the pit entry and the track by a car entering the pit lane is prohibited.
"That's quite literally gaining 1s during VSC, and the lap times also check out. Not sure the difference between your "1.4s moments after VSC was pulled in" and "sudden gap of only 0.8 almost immediately thereafter". Anyway..."dialtone wrote: ↑04 Apr 2022, 02:37That's quite literally gaining 1s during VSC, and the lap times also check out. Not sure the difference between your "1.4s moments after VSC was pulled in" and "sudden gap of only 0.8 almost immediately thereafter". Anyway...Juzh wrote: ↑04 Apr 2022, 00:35To clarify:
