I really hope they won't delay the anti-porpoising measures any longer.
Their quota of making fools of themselves is already filled by the Perez qualifying snafu.
Yes, there is a need. Some teams have worked hard to solve the problem, other didn't have the problem because they might have done naughty things in their initial designs. If someone works hard to solve a problem within the rules, they should prosper compared to someone that solved the problems outwith the rules.codetower wrote: ↑15 Jul 2022, 22:35I haven't seen any drivers complain about the porpoising since the TD was announced. They were complaining about back problems, talking about the long term effects, but since the directive was announced I haven't heard anything. Have the teams already found solutions? Is there still a need for the TD?
Oh well, it is going to change anyway. "They take the step plane out, they put the step plane back, they shake it all about."
What kind of downforce loss will this cause? I imagine it would be significant, which is why the rulemakers got rid of the step plane for these venturi tunnel rules in the first place?The FIA has also outlined, following input from the teams, changes to the technical regulations for 2023.
These are a 25mm raising of the floor edges, a raising of the underfloor diffuser throat, the introduction of more stringent lateral floor deflection tests and the use of a more accurate sensor to quantify aerodynamic oscillation.
All the above measures are to be submitted urgently to the FIA’s World Motor Sport Council for ratification, so teams can get to work on revised 2023 designs.
Wonder why did they got rid of the step plane in the first place, seems really foolish. Actually I thought the sidewalls had to be higher until I saw the Kyle video. When Byrne/Head made their proposal for the 2013 regulations, they also mentioned that the sidewalls are to be higher. (But of course the teams immediately vetoed the proposal, so we get the Mercedes dominant era...) Apparently the F1 taskforce lead by Brawn/Fry forgot about the problems the floors sealing to the ground creates...JordanMugen wrote: ↑15 Jul 2022, 23:51Oh well, it is going to change anyway. "They take the step plane out, they put the step plane back, they shake it all about."
@Fulloppositelock:What kind of downforce loss will this cause? I imagine it would be significant, which is why the rulemakers got rid of the step plane for these venturi tunnel rules in the first place?The FIA has also outlined, following input from the teams, changes to the technical regulations for 2023.
Raising the diffuser throat height is another sensible measure to stop teams pursuing overly ride-height-sensitive tunnel geometries.
Cars still have a step plane, in fact that central section has a huge influence in airflow. The central section is a bluff body.JordanMugen wrote: ↑15 Jul 2022, 23:51Oh well, it is going to change anyway. "They take the step plane out, they put the step plane back, they shake it all about."
Well, no surprise all teams except the Mercedes powered ones (while there are rumors of even Williams being in that boat) are against the changes. We’re far into the season and the teams are already far into the development of their cars for next year. Such a radical change at this stage for “safety reasons” even though porpoising is under control by all teams already, seems just odd.
Not they do not introduce this change because one or two teams are not in compliance with the rules. All teams are in compliance with the rules like they are right now in relation to that. Otherwise they would not be allowed to race their cars. They FIAs intention only was different in regards to the intepretation of this law and now they want to correct this. But that has norhing to do with one team cheating and another one is not. If it would be cheating certain teams would not be allowed to race their "illegal" cars. But they are as it is a different Interpretation of a rule only. And thats F1 and a pretty normal thing in F1. A new TD does only introduces a new technical regulation. Nothing else. Sometimes because the rulemakers did intend the rule to be interpreted like that, sometimes out of political reasons, safety reasons and sometimes because of everything together or something else. And thats it. But its not about cheating or not.Just_a_fan wrote: ↑15 Jul 2022, 23:17Yes, there is a need. Some teams have worked hard to solve the problem, other didn't have the problem because they might have done naughty things in their initial designs. If someone works hard to solve a problem within the rules, they should prosper compared to someone that solved the problems outwith the rules.codetower wrote: ↑15 Jul 2022, 22:35I haven't seen any drivers complain about the porpoising since the TD was announced. They were complaining about back problems, talking about the long term effects, but since the directive was announced I haven't heard anything. Have the teams already found solutions? Is there still a need for the TD?
Edit: and to the person that keeps downvoting me with "unfounded cheating allegations", if the FIA thought every team was within the rules, the TD relating to flexing of the floor wouldn't be needed. They are introducing this change precisely because their is a suggestion that one or more teams are not in compliance with the rules
They don't comply with the rule, they comply with the current metric - the way that deformation is tested. It's exactly the same as the drooping wings from the V8 days - the wings met the test but obviously didn't meet the rule. So the test was changed to reinforce compliance with the rule.Andi76 wrote: ↑23 Jul 2022, 23:42
If you read the rule in relation to that you can clearly see that even the teams who you accuse "to cheat", completely comply with the rule like it is right now. Their floors do not flex more than it is allowed to where the rule says it. It flexes more somewhere else and there is no rule that says it is not allowed to it there. So when someone downvotes you because of "unfounded cheating allegations", he is totally right with that. Sorry to say this - but thats a fact.
Sorry, but i think even discussing this is not worth any time - the rules say that the floor is not allowed to flex more than 2mm and this gets controlled at 2 points. If it flexes somewhere else - they comply with the rule, because you can easily interpret it that the floor is not allowed to flex in this specific area only. Its like saying there is a speed limit and it gets controlled from one point to another. Of course you can understand or interpret this as the speed limit is only in a specific area. And this is F1 - F1 is about finding exactly loopholes like that and it is even stupid not to exploit it. So - you can turn it however you want - its not cheating at all. If thats cheating, DAS was cheating, flexi-wings are cheating, a suspension that lowers the rear is cheating, double-diffusers were cheating, as were a lot of F1 technical innovations. The mistake is with the regulation not with the teams exploiting it. And finally - no car that does not comply with the rules AT ANY TIME - is not allowed to race. So sorry - i say it again - if people downvote you for "unfounded cheating allegations", they are obviously right.Just_a_fan wrote: ↑24 Jul 2022, 14:03They don't comply with the rule, they comply with the current metric - the way that deformation is tested. It's exactly the same as the drooping wings from the V8 days - the wings met the test but obviously didn't meet the rule. So the test was changed to reinforce compliance with the rule.Andi76 wrote: ↑23 Jul 2022, 23:42
Just because you don't get seen by a policeman, doesn't mean you aren't breaking the law when exceeding the speed limit.
