Even if flexing wings were illegal and DAS was actually legit....So long as RB/Max/Honda wins it's all good?
![d'oh! #-o](./images/smilies/eusa_doh.gif)
And there we go again... same for the 'flexing' wings (as materialized in 2021); the rules were rewritten to specifically prevent it being done again precisely because it wasn't illegal according to the (quantitative) rules in force at the time. Difference is that in case of DAS they did it between seasons (fine), in case of wings they did it mid-season (not fine).Just_a_fan wrote: ↑24 Jul 2022, 19:21No, it wasn't. The rules were subsequently rewritten to specifically prevent it being done again precisely because it wasn't illegal according to the rules in force at the time.
No, flexible wings were always illegal but the teams gamed the tests. So the tests were altered to capture more data points to check compliance. Just as is happening with the alleged flexi-floors.DChemTech wrote: ↑25 Jul 2022, 11:12And there we go again... same for the 'flexing' wings (as materialized in 2021); the rules were rewritten to specifically prevent it being done again precisely because it wasn't illegal according to the (quantitative) rules in force at the time. Difference is that in case of DAS they did it between seasons (fine), in case of wings they did it mid-season (not fine).Just_a_fan wrote: ↑24 Jul 2022, 19:21No, it wasn't. The rules were subsequently rewritten to specifically prevent it being done again precisely because it wasn't illegal according to the rules in force at the time.
And then, as discussed ad nauseam in the dedicated thread, all wings are illegal because every material flexes. Without providing tolerances, the rule 'wings cannot flex' is void. The only tolerances that were provided were those contained in the tests, which were passed by the teams, hence the wings were legal. When the tests changed, the tolerances changed, hence the rules changed, which in my view is competition falsification if it happens in the season. And the same applies for the alleged flexi-floors.Just_a_fan wrote: ↑25 Jul 2022, 11:41No, flexible wings were always illegal but the teams gamed the tests. So the tests were altered to capture more data points to check compliance. Just as is happening with the alleged flexi-floors.DChemTech wrote: ↑25 Jul 2022, 11:12And there we go again... same for the 'flexing' wings (as materialized in 2021); the rules were rewritten to specifically prevent it being done again precisely because it wasn't illegal according to the (quantitative) rules in force at the time. Difference is that in case of DAS they did it between seasons (fine), in case of wings they did it mid-season (not fine).Just_a_fan wrote: ↑24 Jul 2022, 19:21
DAS was always legal.
The floors have a defined allowance and an initial set of test locations. If the floor flexes elsewhere from those test locations, it's an illegal floor.DChemTech wrote: ↑25 Jul 2022, 11:46And then, as discussed ad nauseam in the dedicated thread, all wings are illegal because every material flexes. Without providing tolerances, the rule 'wings cannot flex' is void. The only tolerances that were provided were those contained in the tests, which were passed by the teams, hence the wings were legal. When the tests changed, the tolerances changed, hence the rules changed, which in my view is competition falsification if it happens in the season. And the same applies for the alleged flexi-floors.Just_a_fan wrote: ↑25 Jul 2022, 11:41No, flexible wings were always illegal but the teams gamed the tests. So the tests were altered to capture more data points to check compliance. Just as is happening with the alleged flexi-floors.DChemTech wrote: ↑25 Jul 2022, 11:12
It was discussed here at length and shown to be made up rubbish. Lots of analysis with lines on videos showing no movement, that sort of thing.chrisc90 wrote: ↑25 Jul 2022, 11:49I know it’s a bit of a old one, but did anything ever get mentioned about the main wing on the merc flexing last year under the DRS flap?
I only joined between seasons so missed everything from last year on discussions
I know there was footage of it moving quite a bit
Just_a_fan wrote: ↑25 Jul 2022, 12:40It was discussed here at length and shown to be made up rubbish. Lots of analysis with lines on videos showing no movement, that sort of thing.chrisc90 wrote: ↑25 Jul 2022, 11:49I know it’s a bit of a old one, but did anything ever get mentioned about the main wing on the merc flexing last year under the DRS flap?
Then you need to specify tolerances for those other locations, because it will flex there. That was not done, so it cannot be judged as illegal according to the rules as were provided.Just_a_fan wrote: ↑25 Jul 2022, 12:39The floors have a defined allowance and an initial set of test locations. If the floor flexes elsewhere from those test locations, it's an illegal floor.DChemTech wrote: ↑25 Jul 2022, 11:46And then, as discussed ad nauseam in the dedicated thread, all wings are illegal because every material flexes. Without providing tolerances, the rule 'wings cannot flex' is void. The only tolerances that were provided were those contained in the tests, which were passed by the teams, hence the wings were legal. When the tests changed, the tolerances changed, hence the rules changed, which in my view is competition falsification if it happens in the season. And the same applies for the alleged flexi-floors.Just_a_fan wrote: ↑25 Jul 2022, 11:41
If you want a falsification of competition, I give you the removal of qualifying maps - done specifically to help Red Bull compete with Ferrari and Mercedes.
No, the requirement is that the plank may not move by more than 2mm. That's the requirement. It doesn't matter if it's measured at position A or position X, nor does it matter if it's not measured at all - it's not allowed to flex more than a certain amount.DChemTech wrote: ↑25 Jul 2022, 13:06Then you need to specify tolerances for those other locations, because it will flex there. That was not done, so it cannot be judged as illegal according to the rules as were provided.Just_a_fan wrote: ↑25 Jul 2022, 12:39The floors have a defined allowance and an initial set of test locations. If the floor flexes elsewhere from those test locations, it's an illegal floor.DChemTech wrote: ↑25 Jul 2022, 11:46
And I agree, the removal of quali-maps was also competition falsification.
