It is funny. I am probably a bit older than you, but if you ask me then V10โs are definitely notvorticism wrote: โ11 Aug 2022, 15:46The FIA got into the business of aesthetics the past few seasons. The question then becomes where to draw the line: at visual? Or also audible?
The V10 was of course an accident in some sense; it arose iirc out of mandating NA engines and swept volume in the 90s, which led directly to high RPM multi-cylinder arrangements. Whether the FIA intended it or not, they would go on to produce the sound which came to define F1.
https://gpcars4sale.com/wp-content/uplo ... 00x675.jpg
https://i.pinimg.com/originals/50/f3/96 ... 99f2ac.jpg
https://cdn-2.motorsport.com/static/img ... engine.jpg
Perhaps poor wording on my part; what defines vs what is more astounding or evocative. Even some turbo fans appreciate the V10/12 sound, though. For ~50 years cumulative (?) of F1's run it was the sound of high strung NA engines. The general public associates a high pitch sound with F1 and top shelf European motorsports in general IMO.Edax wrote: โ14 Aug 2022, 00:29
the sound that defines F1.
That would be the BMW, Renault and Honda turboโs. Mind you that is the time where you would write โturboโ on your bike to make it go fast, or โlaserโ (whatever that may be). In anyway the V10 was a huge step back, and a sure sign that F1 was on its way to make itself obsolete by clinging on to archaic technology.
Goes to show. Chancing the sound you can never do it right, but in hindsight it always was the best. So it should not be a consideration.
The high pitched sound is a relic of a brief period in F1 where revs went through the roof in order to make power available. For the vast majority of F1's history, the high pitched scream of the V10 was not heard.vorticism wrote: โ14 Aug 2022, 01:18Perhaps poor wording on my part; what defines vs what is more astounding or evocative. Even some turbo fans appreciate the V10/12 sound, though. For ~50 years cumulative (?) of F1's run it was the sound of high strung NA engines. The general public associates a high pitch sound with F1 and top shelf European motorsports in general IMO.Edax wrote: โ14 Aug 2022, 00:29
They were exclusive for a much shorter period than 24 years. And they competed against V8 and V12 engines.vorticism wrote: โ14 Aug 2022, 02:09Brief in the sense of 24 years. Then prior to the first turbo era there was a mix of NA and forced induction spanning thirty years. The earlier NA engines of course were lower RPM, with DFVs and various V12s redlining at 8-12k RPM although these still produced a higher frequency exhaust note than current and historic turbo V6s, and would have contrasted significantly to the compressed engines of their era.
Maybe good to point out that he was referring to thermal efficiency, work/heat input, which had improved quite a bit for road cars.Tommy Cookers wrote: โ12 Aug 2022, 11:06no
what you are all talking about isn't combustion efficiency
CE is just what % of fuel eg 95% is burned in the combustion chamber - that hasn't really been changed
what systems like TJI enable is satisfactory combustion of leaner mixtures than would be possible otherwise
plus F1 architecture (presumably) can have some post-cylinder combustion upstream the turbine
Yeah I can understand where youโre coming from. But I guess that is the same for some of the older series. These really had some unique sounds that were never reproduced in another racing series.NL_Fer wrote: โ14 Aug 2022, 04:02Honestly the 80s turbo pops and bangs were crazy, but they have been heard in other racing cars also in the periode afterwards. But the high revving V8-V10 has never been reproduced outside F1. It is pretty unique and combined with the reverberation around the track, really insane. I miss that allot.
No, the period lasted over two decades. 25 years actually; I wrote 24 in error. You wrote:Just_a_fan wrote: โ14 Aug 2022, 11:51They were exclusive for a much shorter period than 24 years. And they competed against V8 and V12 engines. The V8 and V12 are just as iconic for anyone with more than a brief / passing interest in F1.vorticism wrote: โ14 Aug 2022, 02:09Brief in the sense of 24 years. Then prior to the first turbo era there was a mix of NA and forced induction spanning thirty years. The earlier NA engines of course were lower RPM, with DFVs and various V12s redlining at 8-12k RPM although these still produced a higher frequency exhaust note than current and historic turbo V6s, and would have contrasted significantly to the compressed engines of their era.
Which is what I replied to. 25 years is not exactly brief. You seem to be making a point specifically about the V10 arrangement/sound, although the peak exhaust Hz were roughly similar among the 12s, 10s, and 8s.Just_a_fan wrote: โ14 Aug 2022, 01:46The high pitched sound is a relic of a brief period in F1 where revs went through the roof in order to make power available.
Exactly. The noise that people associate with V10s was also created by V8 and V12 engines.vorticism wrote: โ14 Aug 2022, 18:07No, the period lasted over two decades. 25 years actually; I wrote 24 in error. You wrote:Just_a_fan wrote: โ14 Aug 2022, 11:51They were exclusive for a much shorter period than 24 years. And they competed against V8 and V12 engines. The V8 and V12 are just as iconic for anyone with more than a brief / passing interest in F1.vorticism wrote: โ14 Aug 2022, 02:09Brief in the sense of 24 years. Then prior to the first turbo era there was a mix of NA and forced induction spanning thirty years. The earlier NA engines of course were lower RPM, with DFVs and various V12s redlining at 8-12k RPM although these still produced a higher frequency exhaust note than current and historic turbo V6s, and would have contrasted significantly to the compressed engines of their era.
1989:
2013:
Jousting windmills. My posts above can be quoted directly. Don't let the thread title confuse you.Just_a_fan wrote: โ14 Aug 2022, 22:58So the idea that "V10 is the definitive sound of F1" is total BS.
I doubt many people could really tell the difference between a V12 and V10 F1 engine. Both had a high pitch and both were painfully loud when heard trackside. And many probably wouldn't know the Ford V8 in Michael's Benetton from the Renault V10 in Hill's Williams. Or between the Honda V12 in Senna's MP4/7A and the Renault V10 in Mansell's FW14B.PlatinumZealot wrote: โ15 Aug 2022, 02:11The V10's were the best sound of F1 imo. V12 just about there too.
The V8 exhaust blown diffuser was aurally interesting.
