This might ruin the day for the purists (of this thread) but it shows the antithesis of the modern efficiency drive. 3:1 AFR; where is the air?; the struggle for spark- hence 44 amp mags and why most blow ups happen
Does the burn got hot enough to use as fuel the non-O2 % particles of air?johnny comelately wrote: ↑29 Jul 2022, 12:42This might ruin the day for the purists (of this thread) but it shows the antithesis of the modern efficiency drive. 3:1 AFR; where is the air?; the struggle for spark- hence 44 amp mags and why most blow ups happen
Last time I checked, the oxygen content of nitromethane enables it to burn with much less atmospheric oxygen than conventional fuels.johnny comelately wrote: ↑29 Jul 2022, 12:42This might ruin the day for the purists (of this thread) but it shows the antithesis of the modern efficiency drive. 3:1 AFR; where is the air?; the struggle for spark- hence 44 amp mags and why most blow ups happen
the stoichiometric AFR is freakishly low (1.7:1) with nitromethanedjos wrote: ↑29 Jul 2022, 13:10Last time I checked, the oxygen content of nitromethane enables it to burn with much less atmospheric oxygen than conventional fuels.johnny comelately wrote: ↑29 Jul 2022, 12:42This might ruin the day for the purists (of this thread) but it shows the antithesis of the modern efficiency drive. 3:1 AFR; where is the air?; the struggle for spark- hence 44 amp mags and why most blow ups happen
So it’s not really comparable to petrol. The reason they use giant 44 amp magnetos is its very very hard to get nitromethane burning.
Well it is finally confirmed. Some announcements imminent I expectTHE WORLD MOTOR SPORT COUNCIL APPROVES F1 2026 POWER UNIT REGULATIONS AND UPDATED 2022-2023 TECHNICAL REGULATIONS
Wait, Porsche and Audi are getting an extra £25 mil to develop their PU?Cs98 wrote: ↑16 Aug 2022, 19:46Feel like these new cars will be braking A LOT with the MGU-K to regenerate enough energy to run that 350kW electrical engine. Won't need disc brakes on the rear axle.
No test bench advantage for RBPT/Porsche and AUDI. However, 10 million extra in budget for the first two years, 5 for the third.
More restricted, more prescribed, remove this, remove that. I don't think it could be more bland and pointless.
It seems like it. There's no way they can generate even the same amount with braking.ENGINE TUNER wrote: ↑16 Aug 2022, 19:11With the mguh gone, where will the electrical energy to power the now 50% more powerful 350kW mguk come from? So basically they will just be burning fuel to make electrical energy. An absurd development, they go from capturing wasted energy, to no longer capturing it and creating more for the sake of producing electrical energy for a shorter KERS boost.
They can compensate with the K for the turbo lag.
