2022 Belgian Grand Prix - Spa-Francorchamps - Aug 26 - 28
Spoutnik
Spoutnik
Re: 2022 Belgian Grand Prix - Spa-Francorchamps - Aug 26 - 28
28 Aug 2022, 12:27
It means Max will start on the clean side of the track and Charles the dirty one. It was the opposite before Tsunoda's penalty.
marcel171281
marcel171281
27
Spoutnik wrote:
28 Aug 2022, 12:52
28 Aug 2022, 12:27
You sure? Verstappen will start on the outside now I believe and at that position of the grid, most cars are still driving on the right side (pitlane side) coming out of the chicane.
marcel171281 wrote:
28 Aug 2022, 13:04
Spoutnik wrote:
28 Aug 2022, 12:52
28 Aug 2022, 12:27
You're correct the racing line here makes Charles have both the inside and the clean surface. That said, not sure if I'd like the inside at la source starting p15 with Ocon near me
RZS10
359
None of the grid spots get much rubber laid down as they mostly drive down the middle, maybe P19 or P17, P15 and P13 getting half a car?, then it's a question which get more marbles etc
marcel171281
marcel171281
27
RZS10 wrote:
28 Aug 2022, 13:22
https://i.imgur.com/qS3J7QU.png
In qually everyone sticks much longer to the pitlane side.
There won't be marbles at the start, the track gets sweeped after every session.
RZS10
359
Oh they sweep the track? All of it or just the grid? Wasn't aware of that ... but either way ... what is the advantage of the rubber laid down in quali compared to a track where multiple racing series put down rubber on a racing line? It's very likely to be marginal to the point where it's nonexistent ... and all five starts in F2, F3 and the Porsche Supercup seem to point towards that (also previous years that saw some racing) ...
28 Aug 2022, 11:47
https://i.imgur.com/38poV3P.jpeg
Quali top speeds (without the tow included)
Here's the data with the tows included if you are curious
McLaren have clearly got on top of their drag woes
Are we sure this data is accurate? Williams was getting purple sector 1s. How are they doing that if they only hit 332?
A lion must kill its prey.
Mogster
So far the gravel at track limits seems to be a success. Watching the F3 and F2 races the starts were pretty clean, no one overcooking and ending up in the gravel, no one being pushed there. Makes a change from half the field taking to the run off as it has been previously. Only issue is gravel on the racing line.
wogx
60
Grande Ferrari! #-o
Track temp in the mid 30s right now according to Jolyon Palmer. 15 degrees hotter than yesterday
should help ferrari/merc surely
Gasly starts from the pits too... LOL ! Max p13 on the inside for La source. Charles p14 on the outside..
Bottas qualifies 20th, takes 20 places of grid penalties and starts 2 places out of the points. Amazing
Sainz , Charles, Max on softs. used for sainz i think. perez on mediums and most others too
Flares in croud already. Weren't they banned
GrizzleBoy
GrizzleBoy
33
What the actual **** was that.
