Red Bull RB19
101FlyingDutchman
101FlyingDutchman
Re: Red Bull RB19
Strange little upwash region below the Hewlett-Packard sign though. Bet that’ll get looked at and changed. Otherwise, my my, cleanest flow vis around a pod on the floor I think I’ve ever seen
bauc
35
Re: Red Bull RB19
101FlyingDutchman wrote:
23 Feb 2023, 14:19
That upwash is due to the ''kick'' generated from the floor bulge and I think its there in order for the ''kick'' to re-energize the flow all the way to the back of the car.
Re: Red Bull RB19
So it's an ultra refinement.
This can be ominous for the other teams.
101FlyingDutchman
101FlyingDutchman
Re: Red Bull RB19
bauc wrote:
23 Feb 2023, 14:32
23 Feb 2023, 14:19
That upwash is due to the ''kick'' generated from the floor bulge and I think its there in the order for the ''kick'' to re-energize the flow all the way to the back of the car.
Thank you. It “looked intended” as it’s so clean but hard to tell
kediown
58
Re: Red Bull RB19
There is a vertical slit in the diffuser of RB19 . I think it's to increase the efficiency of the diffuser.
Re: Red Bull RB19
kediown wrote:
23 Feb 2023, 15:29
It's not visible on the other side though. That user has blocked me in the past for pointing out that they report incorrect info. I wouldn't trust it
gandharva
252
Re: Red Bull RB19
So the bleed-out area of the underfloor is now used to generate two vortices that seal the floor. Nice countermeasure to the raised floor edge.
Re: Red Bull RB19
kediown wrote:
23 Feb 2023, 15:29
Here it looks like a slit in other direction. Looks more like a patch of paint on diffuser or a thicker part, with sandwich material inside composite laminate.
niccoaero
niccoaero
Re: Red Bull RB19
It’s a slot which should increase the energy of the fluid travelling on the outer side of the diffuser. In the end the extraction of the fluid should be better
In Italian, but the Article here: https://www.funoanalisitecnica.com/2023 ... re-f1.html
Re: Red Bull RB19
Fabrega with a brilliant photo
Venturiation
Venturiation
100
Re: Red Bull RB19
23 Feb 2023, 16:07
https://pbs.twimg.com/media/FpqCsuoWAAU ... &name=orig
:shock:
Can others teams use this image to reverse engineer it?
BlueCheetah66
BlueCheetah66
33
Re: Red Bull RB19
Venturiation wrote:
23 Feb 2023, 16:08
23 Feb 2023, 16:07
:shock:
Teams have already started using those mini Diffuser kicks. Ferrari and Alfa Romeo had it on their car around midway through 2022, and no doubt some other teams will have added them
FDD
FDD
81
Re: Red Bull RB19
23 Feb 2023, 16:07
If I understand right these kicks are vortex generators, or I am wrong?
Re: Red Bull RB19
kediown wrote:
23 Feb 2023, 15:29
gandharva
252
Re: Red Bull RB19
:mrgreen: Almost organic.
