Mercedes W14
Venturiation
Venturiation
102
Re: Mercedes W14
is it true that the highest downforce rear wing is the one that causes the more porpoising?
if that's so then would that mean that mercedes were controlling porpoising very well during this bahrain testing and with a lower DF wing it will be even better?
the were running the high DF RW to compare with the W13
Evo2racer
Evo2racer
Re: Mercedes W14
So Mike Elliot confirmed they will stick to their concepts of very small/almost zero sidepods !
Plus that they will put a much smaller rear wing when the Bahrain race weekend comes !
Very interesting all these details & confirmations he gave with Ted Kravitz on Sky F1, really fascinating interview Imo
Re: Mercedes W14
Evo2racer wrote:
26 Feb 2023, 20:22
All he said was they would have a different sidepod that wouldn't look like RB/Ferrari. He never said they would still be "very small/almost zero sidepods".
Re: Mercedes W14
I don't see how a lower df rear wing would solve any of the issues the w14 seems to have at the moment
Henk_v
Henk_v
88
Re: Mercedes W14
That's what I posted, bit got modded away I guess. Lots of braking issues, slow on the gas. And that on a max DF rear wing and the front wing cranked up.
Yes, the speed trap will smile on you for losing some drag, but that does not equate to laptime
Femi
Femi
Re: Mercedes W14
26 Feb 2023, 20:25
Eliot mentioned "rear wing" in context of addressing W14 "low" top speed issue
Re: Mercedes W14
They probably planned this new rear wing before the traction and rear-stability issues they've had at testing appeared. If they don't get their setup sorted properly I fully expect them to use the barn door once again
Re: Mercedes W14
Henk_v wrote:
26 Feb 2023, 20:28
It wasn't deleted. Check the general aero thread or the Mercedes f1 team thread. Some cleaning was done.
Henk_v
Henk_v
88
Re: Mercedes W14
Ah, I got confused thanks
mantikos
mantikos
35
Re: Mercedes W14
26 Feb 2023, 20:24
Evo2racer wrote:
26 Feb 2023, 20:22
He clearly said an evolution of our concept/design
Re: Mercedes W14
mantikos wrote:
26 Feb 2023, 20:45
26 Feb 2023, 20:24
Evo2racer wrote:
26 Feb 2023, 20:22
We shall see then.
Evo2racer
Evo2racer
Re: Mercedes W14
Did anyone @ MB explain what happen in the second day of testing ? Why they spent almost all night rebuilding the chassis after day 2 ?
Or a reason why the W14 lost all the front downforce and was almost undriveable on day 2 ?
Re: Mercedes W14
Evo2racer wrote:
26 Feb 2023, 22:25
Not really, but reading between the lines, they must have lowered the car when the issues occurred.
240
Re: Mercedes W14
26 Feb 2023, 20:34
Maybe they were using a high load wing to induce the most df as a test of their new suspension in isolation from preparing for the first race.
Re: Mercedes W14
ringo wrote:
26 Feb 2023, 23:12
26 Feb 2023, 20:34
That makes sense
