v = v0 + a * T
Piston speed at both 0 (v0) and 42 mm (v) is zero => the average acceleration a is zero.
If average acceleration is 3400 g the piston speed at 42 mm is 3400 * 9.81 / 630 = 53 m/s.
High speed engine designers appreciate a lot the reduction of acceleration given by a long con rod, but “long” in the right sense, ie looking at the ratio con rod / stroke. Since high speed engines have usually very short stroke, the rod is, kinematically, pretty long, even if, physically, is possibly a bit shorter than that of a low speed, long stroke, engine.riff_raff wrote: Ultimately though, the reduction in mass provided by a very short, lightweight titanium rod, more than offsets the increased accelerations produced by that short rod geometry. And that's the solution adopted by most high speed engine designers.
So, F1 cars are able to reach such high revs because all the internal components are much, much lighter (and made from far more exotic materials) than a road car. The only way a road car would have as many revs would be to make the engine more like and F1 engine and accept the fact you would need to change it often (and run it in very controlled conditions warm-up/cooling etc.)gabe wrote:Hi,
I was wondering if anyone knew how f1 cars are able to reach such high revs? What would happen if a road car had this many revs? Is it the difference in revs due to the complexities of f1 cars?
thanks
Gabe
